Apply Brake - Loose Right Turn Signal
Bulbs are 1157s and work fine. Left turn signal and brake work fine. Right turn signal stops flashing and stays onwhen I apply brake. What the crap.............over..........
RE: Apply Brake - Loose Right Turn Signal
Same thing, only lights are brighter. I probably need a voltage regulator. In the meantime I'd like to get the signal/brake issue fixed though. Any sugegstions?
ORIGINAL: dano670
I think a turn signal switch might be the culprit. My switch had a problem. Turns signals worked, but only one of the brake lights would work.
my first instint would be the brake peddle interfering with the flasher ground. As you apply the brake, it sounds like you're pinching a ground wire. It can't be a power wire, becaue you're not blowing fuses.
My two cents....
My two cents....
