Toploader questions
Toploader questions
So my four speed is a little jacked up, as when the last person working on it apparently put the linkages on wrong, as my gears are in the wrong place! As far as i can tell, first and second are in the right place, but third and fourth are reversed. the shifter is a hurst. Any one have some info? thanks
RE: Toploader questions
Just a thought.......I don't have a toploader I have a T-10, but.........Check the linkage on the side of the trans and make sure the bell cranks are both up instead of down. If you point them down they will work backwards.
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
treesloth
09-28-2015 07:03 AM
