When do you know it's time for a rebuild?
My car has put on about 15K miles in the past 25 years or so since its last rebuild (just engine rebuild im pretty sure, 170 i6). Would you consider the length of time enough reason for a engine, tranny and rear end rebuild? Or would it not be needed due to the low mileage? What would a rough ball park estimate be on a job like that? I've never been in an engine but I might tackle that rebuild myself.
RE: When do you know it's time for a rebuild?
Any reason for considering getting your engine rebuilt? I would not worry about it if you arent having any problems with it. Do a compression test and check the oil pressure. If no warning flags go up after these tests, like low compression in a cylinder or low oil pressure when the car is at running temp, I would not worry about it.
Same goes for the tranny...if you arent experiencing any problems I wouldnt worry about it. The rear end depends on mileage.
times when you KNOW you need a rebuild
1. Insert key, gently caress dash while whispering words of encouragement, "come on baby, you can start. You don't have to do it on the first try, but please, I need to get to the 7-11 so I don't miss the slurpee sale"
REBUILD ENGINE
2. Driving trough parking lot avoiding any unecessary speed control device. Upon reaching an unavoidable one you gently caress dash wile whispereing these words of encouragement, "okay I promise, last time I take you over one of these, you can do it."
REBUILD SUSPENSION
3. Prior to shifting from park to drive/reverse, gently caress shifter and whisper these words of encouragement, "if you engage and DON'T leave the tranny on the pavement, I'll get you that new high milage oil." REBUILD TRANNY ,"if you engage and DON'T leave the rear end on the pavement, I'll get you those new gears, and maybe a posi unit."
REBUILD REAR END!
REBUILD ENGINE
REBUILD SUSPENSION
REBUILD REAR END!
ORIGINAL: OhioMachIRunner69
umm you mught just need a tune up like new plugs, wires, cap, rotor, timing adjustment, and then you clutch just might need an adjustment those things do wear and need adjustment i know that the self adjuster cable in my brakes is shot cause they don't self adjust anymore
When you cant put oil in with the engine running. its time for a rebuild
When there is a strange knocking sound coming from inside the engine. its time for a rebuild
When its fill the oil check the gas at a station. its time for a rebuild
When there is a rod hanging out the side of the block. its time for a rebuild
If there is no valve where it should have been under the valve cover. its time for a rebuild
If its running good, doesnt smoke or eat oil, isnt making any harsh mechanical noises.. DONT TAKE IT APART!
Yeah soo I have an engine, and um half of the connecting rod is sticking out of the pan, half is stuck in the valve seat, the piston...errr well 1/3 of the piston is in the oil pan one third broke through the cyliner wall one third is sitting in the valve cover.....diagnosis ...BOAT ANCHOR
If the engine keeps running for a second after you turn off the key, then sputters and dies, then your timing needs to be adjusted. You probably have a clutch worn sufficiently to have it replaced. You shouldn't have any issues shifting if the clutch is thick enough to do it's job.
mungodrums
10-07-2015 04:01 AM
