chp 393 stroker
chp 393 stroker
ok im about ready to order my short block either friday or monday i and i dont know witch one i should go with from http://coasthigh.com/Assemblies/Ford/ford_393w.htm the street fighter or pro streetfighter im planning on spraying in the future proble just 150 will the street fighter handle that are should i go with the pro
RE: chp 393 stroker
i would think the street fighter would handle it without a problem, but the pro has a better crank and stronger rods. safe is always a good thing if you can afford it. still seems like you could build it yourself cheaper if you have the knowledge (its not rocket science)
RE: chp 393 stroker
well i can afford it but i still need to do other things like im planning on getting a march serpitine kit i also would like to get some wheels i already have 5,000 set aside for body hopefully i want cost me more then that for the body and then i 7,000 for the engine but like i said i wana try to get the march kit but i do have my heads already and intake
RE: chp 393 stroker
I'm sorry but I'm just not a fan of CHP. But you may want to give us a call and talk to Lloyd about us doing an engine for you with your heads and intake, I know people have sent in their carbs and intakes before. You can also get the Mach upgrade and get the engine completely assenbled when you get it. and the best part of it is that it gets run on the dyno so you know you won't have any problems when you put it in your car. here is the website again if you need it http://tandlengines.com/
RE: chp 393 stroker
p.a.w.(performance automotive warehouse) has a 427 ci windsor for about 2600$ unassembled its a complete motor heads etc just would need ur oil pan and accs
RE: chp 393 stroker
ORIGINAL: white69mach1
i might try giving loyd a call i like that yall in the south east and not all the way in cali. my queston tho is that 408 really makeing 465 hp
Mike
RE: chp 393 stroker
ORIGINAL: my77stang
buying from a company who has people on these forums is great - if you have a problem you can come and complain here 24 hours a day
RE: chp 393 stroker
yuppers. really, the p.a.w. kit would be most excellent though, getting everything shipped to you and all ya gotta do is assemble. makes life easy and you get the pleasure of building the motor. to me thats the most fun and rewarding part of fixing up an old mustang
