66 mustang A/C
Old 02-10-2007, 06:09 PM
66MuStAnG4sho
66MuStAnG4sho's Avatar
Default 66 mustang A/C
I have a 66 Mustang wit a/c. Right now the A/C doesnt work and i cant figure out why. i also dont know if it is Factory Air or Aftermarket. Also i dont know if it is R12 or R134. can anyoe help me out? im in new mexico and its startin to get warmer and i hav black interior which makes for a hot ride...in more ways than one.
P.S. the A/C says FoMoCo on it..if that helps
66MuStAnG4sho is offline
Old 02-10-2007, 06:43 PM
Soaring
I ♥ Acer
Soaring's Avatar
Default RE: 66 mustang A/C
That would be factory air. More than likely, it has R12 in it unless you have had it changed over to 134A. The R12 nipples are smaller than the 134A, so you can't put 134A into an R12 nipple. You just need to take your car to an air con place and have them service it for you. It will be a couple hundred dollars to change to the R134A. Your compressor may not be working either because it could be frozen up or the clutch is burned out. So, get ready for a few hundred dollars for a new compressor as well.
Soaring is offline
Old 02-10-2007, 08:40 PM
66MuStAnG4sho
thanks for lettin me kno...that sux i dont hav that kind of money rite now...guess ill jus hafta roll down the windows. lol
Old 02-10-2007, 08:55 PM
Soaring
I ♥ Acer
Soaring's Avatar
ORIGINAL: 66MuStAnG4sho
It depends on where in New Mexico you are located. I had land up in Cloudcroft in the Lincoln National Forest, and it was quite pleasant during the summer without air conditioning. Now, down in the desert you will fry. However, I drove cars without air conditioning in west Texas for 30 years and didn't die. You just have to open that vent and roll down the windows. It's called a 62 air conditioner. You drive 60 mph with both windows down.
Soaring is offline
Old 02-12-2007, 01:43 AM
JMD
JMD's Avatar
I dont' have "all" of the right tools, but I can make your a/c work. I have done several conversions to r134a without incident, this is probably the way to go. If you decide to do this you will probably need to change your compressor if it has not been replaced in the last few years.
JMD is offline
djbigskrilla
09-20-2022 01:04 AM
SANDY21
08-17-2015 02:41 PM
gagemcc
08-17-2015 10:30 AM
daytooday
08-11-2015 09:22 AM
HIS S-197
08-10-2015 05:47 PM
Quick Reply: 66 mustang A/C
