Floor Pans
Floor Pans
The floor pans in my 67 are rusted through, i have new floor pans that are a 2 piece. Is it hard to replace them myself or should i have someone do it? Also, should i get a one piece floor pan?
RE: Floor Pans
well I would to need more on what type of tools you have to work with. If you got a great weilder and air tools or what not. Maybe a car lift. I would have to know more with what you have to work with. I could give you a better reply on what to do then.
RE: Floor Pans
If only I had a cloning car device I could make so many people heppy! Thanks for the nice complament, very kind.
Did you still want your question for the floor pan answerd? I can help with that.
Also wouldn't mind seeing some pictures of your car.
RE: Floor Pans
i did the floor pans myself on my 66 wasnt to hard aslong as u can weld and use a cutoff wheel and have the pacients to take it in and out about 5 times to get it to fit right its not to bad im only 18 and i did mine myself and i did it with 2 pieces not the 1 just my 2 cents
