independent rear end
i have a 67 fastback and i have heard of people putting an independent t-bird 8.8 rear end in them does anyone know anything about this and would it be hard to do without cutting the whole back end offmy car i have access toone of these t-bird rear ends and a 9 inch and i can have basically either one for freeand would it be worth it to go with the independent rear endfor the handling or go with the 9 inch for strength. im planning on putting close to 400hp in it btw
RE: independent rear end
the 8.8 will more than handle the 400hp its the half shafts that are gonna be the weak link but with as many people that hop up tbird supercoupes there should be some good ones out there
as for going independent thats what the purpose of the fastback in the 1st place but it was cut from the car i imagine ud nee to take the rear frame rails, all the moutning brackets off the floor etc so u could mod it to fit the floorpan off of the tbird to make it happen
if you want to drag race the irs will come back to haunt you if you really want one id go with http://www.mustang-unl.com/itemdy00.asp?T1=CF121+01 its pricey but almost everything in it is bullet proof heres a link of someone installing it http://www.automedia.com/Independent...es20050801ir/1
Heidt's makes an IRS that looks a lot like a Jag. Uses the half-shaft for the upper control arm. They use a 9" with aluminum housing and adjustable coil overs that are also available in double units and it has inboard mounted discs which lowers your unsprung weight drastically. The wheel bearings are based on Corvette pieces. They use a forward, triangle mount type trailing arm set-up. Price starts at around $5300.00 and goes up from there.
I've never driven a car with it but it has to ride better. It looks to have enough adjustable points to get the handling right.
Go to stag-aholics.com for some very good pictures.
ORIGINAL: andrewmp6
ORIGINAL: Shifty101Easy
yeah, and i think the heidts one is bolt on?? or at least almost...? instead of some big modification.....
67 if you got a welder anything can be done cheapest irs i found was http://www.dvsrestorations.com./irs.shtml
Dragonus18
09-09-2015 01:21 AM
