removing headbolts
removing headbolts
so i was planning on dropping my engine of a the machine shop tomorrow and i started stipping the engine down and im a pretty big dude and i can not get the heads bolt to turn a bit i sprayed some wd40 on the bolts and still no luck any tips on gets the suckers to turn im pretty sure the heads havent been of probly atleast 15 years if not more
RE: removing headbolts
well i use pb blaster (made the switch and am glad) umm have you tried hitting them get something metal that can make contact with the bolt and strike it with a hammer a couple of times on each bolt but don't do it to hard you want just enough of that vibration from the hammer to break that bond or the fritction another tried and true way is get a propane torch and heat that sucker up hot then apply penetrant and lastly get a lond pipe and use it as leverage and go real slow as not to break anything
A 1/2 inch breaker bar with pipe on it or a good impact gun. Save the PB, WD or whatever else you care to use because there's no way it's going to work it's way down to the threads on the head bolts.
