best place for stroker kits
RE: best place for stroker kits
yup, 19cc dish is exactly what you want. ditch the intake you have now and grab a edelbrock performer rpm airgap at the very least, or really go nuts and throw a victor jr on there. PORT MATCH the intake runners to your heads, because you have larger intake ports and it would be a shame to not let everything flow the way it should. deck the block, and make sure the machine shop balances everything using YOUR flywheel and balancer.
for a carb, i'd prolly put a 750 on there, vacuum secondaries for street driving or a double pumper for the track - but definately a holley or a barry grant. if you havent gotten your ignition yet go pickup a crane fireball you'll be happier than having a msd 6al (i know this from personal experience)
http://store.summitracing.com/partde...p;autoview=sku
"Their built-in rev limiter automatically drops cylinders in firing order to prevent fuel loading, and is adjustable from 3,100-9,900 rpm in 100-rpm increments, without any chips."
oh yeah, and its only 490.00 for both and that dizzy KICKS ***!!!!
I'm running a 10.1 compression with dished pistons and it runs great on premium octane pump gas. I have Eagle crank and rods with JE pistons. And77stang is right... this motor will be NASTY!!!! [sm=burnout.gif]
ORIGINAL: white69mach1
what type of carb would be good to run on this setup
yes they are swapped i live where the big storm hit a cpl years ago and well everybody and there momma is getting fema money and getting engines built with that and theres only one machine shop here in the mississippigulfcoast
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
09-01-2015 08:16 PM
