Flywheel install question: orientation?
I'm installing my new clutch and flywheel, which I had balanced to my engine, however I realized that I have no idea what it's orientation needs to be. There's a dimple in the end of the crank between two of the flywheel bolt holes, does that indicate anything? Neither my 65 - 73 manual or my 89 - 92 manual says anything about where the weight has to go with regard to the crank position, but there must be a specific position that is correct, right? How do I know what that is?
I'm trying to get this done tonight, so a quick answer would be much appreciated.
RE: Flywheel install question: orientation?
Nevermind, I just figured it out. For anyone searching for the answer to the same question, the holes in the flywheel/flex plate only line up one way with the ones in the crank.
09-10-2015 08:39 PM
