SC
RE: SC
ok but these are just toughts... if i would go with a paxton novi 1200 bolt on kit.. what do i need to get to the 75%.. ore what should i change to get up to higher psi 10-14, rods ?? i have wread some posts about sc in this forum.. the egine is a 302.. all that i know is changed to the engine is exhaust.. the gas in sweden is 99 octane.. do i need a cooler (inter, after?) to be able to use the sc?
http://www.paxtonauto.com/systems.as...t&Part=1001839
http://www.proficientperformance.com...stang_novi1200
RE: SC
Be very careful what you ask for. Can your longblock hold that much pressure without breaking something? Do you have forged pistons and rods? Is your crank steel or nodular iron? Can your oil pump handle the new component? Etc...?
What is your current engine configuration?
RE: SC
That's actually the best way to be...start from scratch to build a blower motor. Lower static compression, special cam, strong longblock, proper electronics...theres got to be many write ups in the magazines with useful advise.
