Engine stalls - intermittent
Old 04-04-2007, 01:01 PM
Mach1972
Mach1972's Avatar
Default Engine stalls - intermittent
I have a 1972 Mach 1 (351C/FMX). I was driving around town a couple weeks ago and out of the blue, my engine dies. It restarted easily and the died again upon acceleration. I limped it home after many restarts and began to try to diagnose. Since then, my mechanic friend and I have tried to find the problem. It will run fine for a mile test drive without even a hiccup, next time I can't even get it out my driveway. It idles fine. Since it is intermittent, it's been impossible to pinpoint the problem. We have done the following so far:
Changed pertronix back to points
New ignition switch (discovered old one had some melted wires)
Went through and reapaired all wiring in engine and dash wiring harness
No water in fuel although at one point the gas looked a dark gold color in the glass fuel filter instead of the light yellow
Meter tested all electronics including coil
New points, condenser, plugs, cap, rotor, wires
All (stock) accessories work fine
Any input would be GREATLY APPRECIATED
(I'm losing sleep over this one) THANKS!
Mach1972 is offline
Old 04-04-2007, 01:24 PM
Cogtx
Cogtx's Avatar
Default RE: Engine stalls - intermittent
Seems like the problem of the week in this forum has been carb issues. If I were to guess, possible rust build up in gas tank which got into the carb causing intermittent blockage. Do you have the original gas tank and sending unit? Fuel line might be a little dirty as well....check the carb and rebuild...keep us posted on your progress...
Cogtx is offline
Old 04-04-2007, 02:40 PM
Mach1972
Mach1972's Avatar
My mechanic took the top of the carb off (Carter 625 AFB) and found a small amount of residue in the bottom of thebowl(s), somewhat grainy, but VERY fine in texture. It had a blueish/green tint to it. What could THIS be? Could it be the cause?
Thanks.
Mach1972 is offline
Old 04-04-2007, 03:06 PM
NorCalTroy
NorCalTroy's Avatar
How about a clogged fuel filter? When was the last time you changed it?
NorCalTroy is offline
Old 04-04-2007, 03:30 PM
Mach1972
Mach1972's Avatar
Brand new fuel filter...see thru glass type. Completely clean.
Mach1972 is offline
Old 04-04-2007, 03:38 PM
Mach1972
Mach1972's Avatar
What would be the best way to determine ifthis problem is electrical or fuel related? Thanks
Mach1972 is offline
Old 04-04-2007, 04:32 PM
JMD
JMD's Avatar
ORIGINAL: Mach1972
The very first thing that came to my mind when reading your post was a defective coil. The issue is certainly an intermitant one, so metering your coil may not provide you of the evidence that it is defective.
A clue to a defective coil might be some of the fluid leaking through the seams, but it can be defective without leaking.
My brother in law had to replace an MSD coil after being on his car for only about 2 months. The issue was intermitant for a while, then the car stopped running all together.
In addition, if you are metering a coil as to the voltage passing through the coil, it may read "ok" while still being shorted out internally. In order to meter the coil, resistance, (ohms), will need to be checked and verified while it is malfunctioning. Unfortunatly, I have no idea what level of resistance a coil is supposed toimpose, but it is certainly much more than "0".
JMD is offline
Old 04-04-2007, 05:22 PM
paddy187
paddy187's Avatar
I am thinking rust intank, as he talks fuel colour and stuff in fuel bowl of carb. So i would be tempted to think about changing the gas tank, pretty easierly done and not too expensive and is not a bad idea anyways.
paddy187 is offline
Old 04-04-2007, 11:09 PM
Mach1972
Mach1972's Avatar
OK, Drained the gas tank and no sign of rust or corrosion. Nothing on the "sock" either. What should I checknext?
Mach1972 is offline
Old 04-05-2007, 03:35 AM
az1966
az1966's Avatar
have same issue,,just got last rid of rubber fuel line stuff with fuel injector rubber lines ( they have a wierd blue rubber coating inside) acid bath for my tank right off the bat,,but you never know
az1966 is offline
Quick Reply: Engine stalls - intermittent
