What advance for 351W ignition ?
Old 05-13-2007, 02:31 PM
rouge67
rouge67's Avatar
Default What advance for 351W ignition ?
What is the right advance on my 351W with stock camshaft and Pertronix ignition ? My Haynes manual says 6° for '69 and 10° for '70.[sm=chattypair.gif]
rouge67 is offline
Old 05-13-2007, 03:41 PM
66GTKFB
66GTKFB's Avatar
Default RE: What advance for 351W ignition ?
Stay with the 6 degrees.
Jim
66GTKFB is offline
Old 05-14-2007, 06:04 PM
rouge67
rouge67's Avatar
Some explanations ?[sm=thanx.gif]
rouge67 is offline
Old 05-14-2007, 06:24 PM
Soaring
I ♥ Acer
Soaring's Avatar
I tweak mine with my ear. It will be set at slightly different degrees depending on the elevation you are at and the octane of the gas you are using. Set it at about 8 and see if the engine knocks under load, if not then you are probably good to go. If it does, then move it back to 6.
Soaring is offline
Old 05-15-2007, 05:01 PM
rouge67
rouge67's Avatar
Thank you Soaring, between 6° and 10° the engine runs good, with better RPM near 10°. What is good ?
rouge67 is offline
Old 05-15-2007, 05:37 PM
Soaring
I ♥ Acer
Soaring's Avatar
ORIGINAL: rouge67
I'm running at about 10 and my 289 runs like a scared jack rabbit. Try it there for awhile and see if the engine heats up or not.
Soaring is offline
Old 05-15-2007, 06:07 PM
my77stang
my77stang's Avatar
if you can get away with 10 thats best - just listen for pinging under a load
my77stang is offline
Old 05-15-2007, 09:25 PM
Decurion
Decurion's Avatar
ORIGINAL: my77stang
exactly.
Decurion is offline
Old 05-16-2007, 12:34 AM
NorCalTroy
NorCalTroy's Avatar
I set my 1969 351w at 10 degrees BTDC and have had no problems. I do run 91 octane fuel all the time though, that makes all the difference in the world.
NorCalTroy is offline
Old 05-18-2007, 06:24 PM
rouge67
rouge67's Avatar
Ok, but here in Europe the octane number is 95. Then ?
rouge67 is offline
Quick Reply: What advance for 351W ignition ?
