Painting Progress with more to come...
Today was aproductiveday, we have got a lot accomplished the past two weekends. There is quite a bit more to be done but the paint laid down nicely. The falsh kind of throws off the color I will try and take some day shots and throw them on.....
we did the door jams....
We also did the doors....
Painted a base on the hood but it is not done yet... Oh and in the back on the parts cleaner is my master cylinder...
Oh and here is a random picture of my Dogs....
RE: Painting Progress with more to come...
What we did is-
-Removed interrior- (including wiring harness, gauges, all switches, ash tray etc.)
-sanded down interrior with 36 grit paper followed by 220 or 400 grit.
- wiped down interrior with nason thinner to remove imperfections and surface dust.
- mixed primar to specifications (Nason primar Dupot equivalent)- I will find the can tomorrow
- Sprayed 2 coats of the primar
- sand primar with400 grit and then touched up troublesome areas with a scuff pad ( the maroon Pads)
- Mixed paint to specifications
- Nason 2K urethane- full thane - single stage
- Added NAPA 87 Fish eye eliminator ( Eliminator is very important)
- Sprayed a heavy coat and let sit for about 20 min and then sprayed a second coat.
- I will post dry pictures tomorrow
The color is cool. Is that the sunset orange color I see on a few of these mustangs on this site? You should hang anything shot off the car. You'll see why when you have to peel the door off the cardboard.
[align=left] [/align]
Nason - Dupont Mixed pro Grade
766932IB
Sunset Orange- effect
Code N8
I know it should be hung but only one side is shot i will shoot the outside of the doors when i shoot the car and the doors will be on the car. I have not had to peel them yet so i think i am ok.
766932IB
Code N8
the thinner that is used in the paint ,not normal laquer thinner. It works really well to clean it off and as long as you let it dry i don't see a problem with it.
