What's the cubic inches on a .030 over 289?
Old 06-20-2007, 02:52 PM
  #21
JBradley500
JBradley500's Avatar
Default RE: What the cubic inches on a .30 over 289?
bore*bore*stroke*#of cylinders*0.7854=displacement
JBradley500 is offline
Old 06-20-2007, 03:11 PM
  #22
highhilleer
highhilleer's Avatar
ORIGINAL: 66GTKFB
Why don't you give it a try? No names, just grades. Seven posters, you included, and one repeat.
Jim
Because I'm a professional grader and this is a hobby. [8D]My post has typos so I wouldn't give myself anything higher than a C. It's not just math, gotta include communications.
JBradley500 also has a correct formula as 0.7854 = PI/4, so this constant includes the conversion of diameter into radius.
highhilleer is offline
Old 06-20-2007, 03:12 PM
  #23
JMD
JMD's Avatar
ORIGINAL: JBradley500
You forgot your pi,,,,,,,
would you like a piece of pie.............
JMD is offline
Old 06-20-2007, 04:11 PM
  #24
royal68
royal68's Avatar
ftw
eleventeen
royal68 is offline
Old 06-20-2007, 05:30 PM
  #25
JBradley500
i always use .7854 because i think of a circle and a square with the same diameter...
if both were 4" diameters then the circles area would be 4*pi=12.56... and the square would be 4*4=16... 12.56.../16=.7854
this means a circle has 78.54% of the area of a square if they both had the same diameter, and since a piston is in a circle shape it only makes sence.
this is the reason the formula makes sence and i use it because it makes sence to me lol
Old 06-20-2007, 05:47 PM
  #26
Soaring
I ♥ Acer
Soaring's Avatar
ORIGINAL: 66GTKFB
The grades are in after my initial post with the formula:
3 get an 'A'
1 gets a 'B'
1 gets a 'D'
2 get an 'F'
There was one repeat entry. As I said - 'Remember all that crap they taught you in school', evidently not.
Comments Glen?
Jim
I suck at math. 292 and change sounds about right, but how does that affect the horsepower? OK math gurus. You have gone from 289 cubic inches to 292 by boring 0.030 over. Now, how much horsepower have you added to that engine if any? Show each step of the math.
Soaring is offline
Old 06-20-2007, 05:50 PM
  #27
66GTKFB
66GTKFB's Avatar
Area of the cylinder (the bore)- times its height (the stroke) - times the number of cylinders - equals enginedisplacement. Grammer school math.
Jim
66GTKFB is offline
Old 06-20-2007, 06:06 PM
  #28
Soaring
I ♥ Acer
Soaring's Avatar
Yeah, but how does boring 0.030 affect the horsepower?
Soaring is offline
Old 06-20-2007, 06:10 PM
  #29
JMD
JMD's Avatar
ORIGINAL: Soaring
ORIGINAL: 66GTKFB
3 get an 'A'
1 gets a 'B'
1 gets a 'D'
2 get an 'F'
Comments Glen?
Jim
292.87 divided by 288.52 = 1.015% increase in displacement, assuming 300 HP with standard bore = 304.5 HP assuming all efficiency issues remain constant, and proportional increase in power,,, ... so 4.5 HP???
JMD is offline
Old 06-20-2007, 06:14 PM
  #30
Soaring
I ♥ Acer
Soaring's Avatar
Thanks James.....that sounds about right. You'd be surprised at what some guys will do to their engines to gain 4.5 horsepower.
Soaring is offline
Quick Reply: What's the cubic inches on a .030 over 289?
