9 inch rear in 65 stang ?
Old 06-28-2007, 12:32 PM
dimariar
dimariar's Avatar
Default 9 inch rear in 65 stang ?
Got a question. Can I put a 9 inch rear in a 65 stang? If so what mods do I have to make.
dimariar is offline
Old 06-28-2007, 01:16 PM
dodgestang
dodgestang's Avatar
Default RE: 9 inch rear in 65 stang ?
Yes and none.
dodgestang is offline
Old 06-28-2007, 01:27 PM
66GTKFB
66GTKFB's Avatar
A lot of help Nick (dodgestang) was.
Yes you can put a 9 inch rear axle in a 65 Mustang but it has to be from a 64 to 66 Mustang to fit. The housing is unique to those years. The other options are to have a custom made axle or a cut down variety from a different year Ford.
Jim
66GTKFB is offline
Old 06-28-2007, 01:28 PM
Soaring
I ♥ Acer
Soaring's Avatar
Just make sure the length of the axle housing is no more than 57.25 inches from flange to flange. 67 and up have a 59.25 inch axle.
Soaring is offline
Old 06-28-2007, 01:42 PM
dodgestang
dodgestang's Avatar
ORIGINAL: 66GTKFB
Jim
What? I answered the question. Sheesh
57-9 Ford nine inch housing are also a direct bolt in.
If you buy a setup with a long pinion you might have to shorten the driveshaft slightly if you don't have enough depth left in the tranny, but if you pick up a center section that is not the extra long pinion, you will not have this problem.
Old 06-28-2007, 02:27 PM
66GTKFB
66GTKFB's Avatar
Nick,
A much better answer.
Jim
66GTKFB is offline
Old 06-28-2007, 04:21 PM
mustube
mustube's Avatar
ORIGINAL: 66GTKFB
Jim
I thought those were 8 inch axles in the 64 - 66 mustangs... are they 9 inchers?
mustube is offline
Old 06-28-2007, 05:09 PM
66GTKFB
66GTKFB's Avatar
A 9 inch rear axle was standard on a 289 Hi-Po engine equipped car and possibily on others with a special order.
Jim
66GTKFB is offline
67LimeCoupe
09-30-2015 04:46 PM
Ryan Fitzpatrick
09-14-2015 02:21 AM
robjh22
Suspension
09-08-2015 12:47 PM
09-08-2015 11:50 AM
09-01-2015 08:16 PM
Quick Reply: 9 inch rear in 65 stang ?
