Bad vibration
Bad vibration
I have a 72 coupe that has a bad vibration. The faster i go the less the vibration.
I'm thinking it has something to do with the tires. its like every other rotation is when it vibrates.
any ideas or suggestion would be great.
RE: Bad vibration
The first thing I would do would be to take it to a tire shop and have them check the balance of all four tires. If one of the tires is out of round, they can tell you. Then you just need to replace that tire. If all the tires are balanced, and it continues to do it, I would suspicion the Universal joints. If they have grease zerks in them, you might want to grease the old ones up first before replacing them.
RE: Bad vibration
Thanks for all the replies. Im taking the stang to a local tire shop in the morning to have all four tires checked and balanced. Also i checked the drive shaft and found a small dent near the rear of the shaft, its not a very big dent about the size of a quarter. Would that throw of the balance of the drive shaft.
RE: Bad vibration
Depends how it got dented...could have knocked off a weight or bent the shaft a little.
If the tires don't fix it, you may need to have the shaft straightened and/or balanced, but check the u-joints first.
