Putting on Holley Heat Shiel with My 4 Hole Spacer
Old 07-10-2007, 07:14 PM
palerider
palerider's Avatar
Default Putting on Holley Heat Shiel with My 4 Hole Spacer
Probably a stupid question so let me have it if necessary.
Currently running a Holley on inch 4 hole spacer. Added the spacer primarily to raise the carb/filterbase high enough so that awith rubber seal I have on topof it would be flush with a hole in hood (poor mans ram air).Heard the 4 hole gives better torque so went with that. In any case bought a heat shield due to having hard start problems when engine is hot.
The kit comes with an open phenolic spacer (3/8"),a bushed aluminum shield, and carb gasket. What I was questioning is what order from intake to carb should I installkit and the 1" 4 hole spacer.
If install heat shield on top of 1 inch spacer - I would be going from intake,4 hole spacer,3/8" open phenolic spacer, shield then carb. Which would seem to give me the best heat protection but was concerned about having open spacer inbetween carb and 4 hole spacer.
Could go intake, phenolic spacer, sheild,4 hole spacer, then carb but was concerned my not be getting best heat protection that way.
Again probably stupid question (would not be the first) - but what do you think?
palerider is offline
Old 07-10-2007, 07:32 PM
fast66
fast66's Avatar
Default RE: Putting on Holley Heat Shiel with My 4 Hole Spacer
Keep your four hole up to the carb. Tt should go - Intake - gasket - heatsheild - gasket - open spacer (if at all)- four hole spacer -carb. The reson I say if at all for the open spacer, is becuase its in the kit for people who dont already have a phenolic spacer. Im assuming your four hole is phenolic, not aluminum, so you already have the heat protection that gives. You can put it in if you want, but its up to you.
fast66 is offline
Old 07-10-2007, 08:19 PM
palerider
palerider's Avatar
ThanksI should have mentioned that the 4 hole is aluminum.
Old 07-10-2007, 08:55 PM
fast66
fast66's Avatar
OK - Then---
Intake
Gasket
Heatshield
Open phenolic spacer
gasket
Aluminum four hole Spacer
gasket
Carby.
The gaskets are your choice depending on how well the various items seal, but to avoid possible vacuum leaks, I would go with the gaskets bteween everything.
Your other option, is to get yourself a 1" four hole phenolic spacer (to repalce you aluminum one), and dont fit the open one with the kit. Youcan prabably pick oneup for the cost of all the extra gasketsyou would otherwise need.
fast66 is offline
Old 07-11-2007, 06:07 AM
palerider
palerider's Avatar
Thanks
Old 07-11-2007, 06:28 AM
Soaring
I ♥ Acer
Soaring's Avatar
You don't need the aluminum spacer. The phenolic is plenty for heat protection.
Soaring is offline
Nick Oliver
10-17-2018 04:22 AM
copestang
10-11-2015 07:17 AM
Pyrate Dave
09-10-2015 07:30 PM
Webster454
09-07-2015 04:59 AM
aleit2013
09-04-2015 11:58 AM
Quick Reply: Putting on Holley Heat Shiel with My 4 Hole Spacer
