9 inch rear end??
Old 01-17-2005, 02:42 PM
tkoppab
tkoppab's Avatar
Default 9 inch rear end??
i needed to know if anyone knows how to tell the difference from a 9 inch rear end and a 8 inch? well i know what the 8 looks like but i need to know how to identify the 9 inch, and in more than just one way too. the car is a 1966 mustang so if anyone knows please help, thanks
tkoppab is offline
Old 01-17-2005, 03:17 PM
carizzma
carizzma's Avatar
Default RE: 9 inch rear end??
9" info. Check it out.
http://www.quickperformance.com/ninecase.htm
carizzma is offline
Old 01-17-2005, 05:09 PM
Soaring
I ♥ Acer
Soaring's Avatar
If it is a stock 66, then you have the 8". Carizzna gave you a very good example of what to look for if an upgrade was added.
Soaring is offline
Old 01-17-2005, 05:46 PM
horseshoeing
horseshoeing's Avatar
Very few people put 9" rearends under a mustang. I did only because I wanted the disk brakes and I had a I6 in my car.
horseshoeing is offline
Old 01-17-2005, 06:26 PM
69mach1377
69mach1377's Avatar
For the most part, the rear hump in the middle is the easiest way to tell if it is a 9 incher...
69mach1377 is offline
Old 01-17-2005, 06:58 PM
vfast
I ♥ Acer
vfast's Avatar
it pretty easy to tell a 9" ..I have to say that's a great site..good work!
vfast is offline
Old 01-17-2005, 09:06 PM
69FECoupe
69FECoupe's Avatar
If you can get a socket with an extension on all the bolts holding it in, it's an 8". On a 9", you have to use a wrench on one of the bolts.
69FECoupe is offline
SSRFUZZY
Members Other Vehicles
01-06-2016 08:22 PM
mungodrums
10-07-2015 04:01 AM
Dragonus18
09-09-2015 01:21 AM
09-01-2015 08:16 PM
Quick Reply: 9 inch rear end??
