rear end gearing
RE: rear end gearing
What are you trying to do? Good gas mileage or high performance? Ever gear set is a compromise between the 2. The best all around ratio however for the 5 speed is around the 3.40-3.55 range
I agree with all those that said around the 3.50:1 range depending on desired application with one exception, which T5 are you running? The reason I ask is that 1st gear is different depending on the type of T5. I have a Z spec T5 and the first gear is 2.95 so I can run lower gears in the 3.50:1 to 4.11:1 rage with better results and a still usable first gear. The majority of the T5s in 5.0 cars were 3.35 so at that point you need to do as other suggested and stay close to 3.50:1
Daze, aren't there a number of different 5th gear ratios for T5's as well?
Just a thought...to make sure the car is not running in that 1900 -2100 rpm range in 5th at highway speed so as to avoid droning exhaust.
My T5 has the 3.35 first gear, and the .68 OD. I think it matches quite nicely with my 3.73 rear end, though a 3.50 would have been ok. All that is behind a 408W making 400 hp, 500lbs of torque at the rear wheels. It really jumps up and runs, but its not too bad on the highway. I just drove it home to Texas from California.
ORIGINAL: Aussie66Fastback
Here's a chart to look up your gears:
http://www.allfordmustangs.com/Detailed/349.shtml
ORIGINAL: superdavid
