Winter storage
Old 08-21-2007, 08:42 PM
Dancin52
Dancin52's Avatar
Default Winter storage
With fall almost here, I'll be storing the car for the winter. Other than having the car up on jack stands, any suggestions?
Dancin52 is offline
Old 08-21-2007, 08:49 PM
Scott H.
Scott H.'s Avatar
Default RE: Winter storage
Scott H. is offline
Old 08-21-2007, 08:51 PM
Galactusz
Galactusz's Avatar
I live in California, so your question is very alien to me.
Galactusz is offline
Old 08-21-2007, 08:54 PM
muggsy
muggsy's Avatar
I live in MA and the question DEPRESSES me....can't belive its the end of August already and the long cold winter is just around the corner...its 60 degrees here tonight (albeit below average, should be warmer) but its reminding me its almost time...
Info on this subject in the FAQ
muggsy is offline
Old 08-22-2007, 06:45 AM
andrewmp6
andrewmp6's Avatar
i take the rotors off and put them in air tight bags to keep the rust on them to a mini.take the battery out place it on wood.id even put some silica packets in the floor board so any moister in the air they will suck it up.
andrewmp6 is offline
Old 08-22-2007, 07:00 AM
Soaring
I ♥ Acer
Soaring's Avatar
If you dojn't jack it up, at least put some lumber under the tires. Put some clothes dryer sheets in the interior and do not set the parking brake.
Soaring is offline
Old 08-22-2007, 07:20 AM
03Mach69Mach
03Mach69Mach's Avatar
If no jack stands, pump up the tires to max sidewall pressure. If they are radials, you are okay, bias ply and you will want to get them off the floor. +1 on Stabil or other fuel stabilizer. Good car cover is a must and a dehumidifier in the garage is a good idea for concrete floors.
03Mach69Mach is offline
Old 08-22-2007, 07:34 AM
Soaring
I ♥ Acer
Soaring's Avatar
Yeah, the reason for the lumber under the tires was because of the moisture sucked up into the concrete, and most garages don't have a dehumidifier. Too expensive to run.
Soaring is offline
Old 08-22-2007, 08:09 AM
blueovalboy7
blueovalboy7's Avatar
ORIGINAL: Galactusz
+1 Sunny so-cal, but I feel for you guys who have to store your stangs, that has got to be depressing.
blueovalboy7 is offline
Old 08-22-2007, 08:20 AM
Soaring
I ♥ Acer
Soaring's Avatar
Now that I am retired, I don't store mine anymore.Been there, done that. I drive mine every day of the year now. But, when I did store it, I had a trickle charger hooked up to the battery that kept the battery fully charged but not over chargerd. The little unit costs about 50 or 60 bucks, but well worth it in saving batteries.
Soaring is offline
Quick Reply: Winter storage
