will a c6 bolt up to my 302
Old 08-23-2007, 11:03 AM
dugan
dugan's Avatar
Default will a c6 bolt up to my 302
hi, been on this forum for a while but have never posted anything.
i am new to all this so i dont know but i ran across a used c6 that is pretty cheap and was thinking about buying but i dont know if it would fit.
i dont know if it matters but i have a c4 right now
dugan is offline
Old 08-23-2007, 01:12 PM
Mr. Classic EFI
Mr. Classic EFI's Avatar
Default RE: will a c6 bolt up to my 302
The C-6 is made for a larger displacement engine, and is not the best choice for a small block. It can absorb as much as 60HP just to drive the tranny, wast of gas HP.
A C-4, or AOD/AODE is a much better selection. I prefer the benefits of an overdrive tranny, you can gear lower, for better performance, and retain fuel saving, benefits of an overdriven top gear.
One way or another, the C-6 is a good choice only if you have no other, economically feasable choice. Save you money.
Mr. Classic EFI is offline
Old 08-23-2007, 01:49 PM
JMD
JMD's Avatar
+ it is my understanding that any c-4 will bolt to a SBF with the right bell housing, but the majority of c-6s will not bolt to a SBF... because they were used most often behind big blocks and "m" motors that used a different bolt pattern. The bell housings on a C-6 is not removable...
Come to think of it, I have a c-6 that was bolted to my 351 when I bought it,,, so SBF / C-6 combos may be more common than I thought...
Just be careful,,, and remember Mr. EFIs advise.
JMD is offline
Old 08-23-2007, 03:17 PM
fastbackford351
Foghorn Leghorn
fastbackford351's Avatar
Location: I reside in a near constant state of amazment.
I have a C6 behind my 351W. Another thing to consider is that a factory crossmember will not fit on the transmission when using the 302/351 - C6 combo. You will have to fab something up.
If the transmission wasn't already in the car when my brother got it 20 years ago, I would have opted for the C4, but the damn C6 just won't die!!
fastbackford351 is offline
Old 08-23-2007, 03:23 PM
JMD
JMD's Avatar
ORIGINAL: fastbackford351
C-6s are rugged SOBs......
JMD is offline
Old 08-23-2007, 06:30 PM
tarafied1
tarafied1's Avatar
The C6 was available in Mustangs starting in 67. The 67 and up C6 used the same trans crossmember as the FMX. The drive shaft and crossmember from a C6 equipted Mustang would fit 65 and 66 Mustangs but you would need a U-Joint to mate the bigger drive shaft to an 8" rear. The Mustang shift lever from a floor shift C4 will also fit the C6. The C6 is tuff and will fit. The bellhousing isn't removable as has been said so you would need a SBF pattern.
I do agree that a AOD would be nice, but consider the cost of one and the custom drive shaft, cross member and TV cable. A C4 can be built to handle a lot of HP but a stock C6 will too.
Good luck.
Craig
tarafied1 is offline
Old 08-23-2007, 07:53 PM
xswoopr
xswoopr's Avatar
You also have to consider whatengine it came from, the spline size could also be a factor.
xswoopr is offline
Old 09-18-2019, 11:43 PM
Kuhnhausen
Kuhnhausen's Avatar
I pick up a 302 with a C6 transmission, factory mated, out of a 1971 ford torino and installed it in a 66 mustang with no modifications.
Kuhnhausen is offline
LindenBruce
04-13-2010 10:54 PM
majpain78
10-21-2007 01:04 AM
dgulian
10-10-2007 06:12 PM
boogerschnot
03-10-2007 02:09 PM
97STANG
02-11-2005 12:03 PM
Quick Reply: will a c6 bolt up to my 302
