Jacking up a Classic Mustang...
Old 08-25-2007, 12:14 PM
bignasty34
bignasty34's Avatar
Default Jacking up a Classic Mustang...
Does anyone have a picture or diagram of solid points to jack up a classic Mustang (a 1966 is what I have). I have a diagram for the 1999-2004 models, and would like to have one for my classic Mustang.
Thanks.
bignasty34 is offline
Old 08-25-2007, 02:26 PM
4reboy
4reboy's Avatar
Default RE: Jacking up a Classic Mustang...
I odn't have a diagram, but I know you want to jack it up on the frame rails. Also there is a nice grame peice in the front of the car you can reach (not sure if the front valence gets in the way, mine was off . So yeah just the frame rails, front and rear.
4reboy is offline
Old 08-25-2007, 02:28 PM
JamesW
Moderator
JamesW's Avatar
Jackstands under the front frame rails about 6" back... roughlyunder the pedals.
Jackstands under the rear should be on the axles.
JamesW is offline
Old 08-25-2007, 04:50 PM
Arcticspook
Arcticspook's Avatar
Agree with James. That is where I put my 67'.
Arcticspook is offline
Old 08-25-2007, 04:53 PM
rmodel65
Yukon Cornelius
rmodel65's Avatar
the pinchwelds are also a sutiable jacking location just like your late model
rmodel65 is offline
Old 08-25-2007, 05:10 PM
gothand
gothand's Avatar
You question was onlifting points, not jackstand points, correct? When I lift the front off of the ground I place a block of wood onthe jack under the front crossmember just below the radiator. For the rear I put the jack right under the rear diff. Obviously, if I were changing a flat on the street I'd use the stock jack and factory lift points on the pinch welds.
Jeff
gothand is offline
Old 08-25-2007, 05:27 PM
five pt oh
five pt oh's Avatar
I know one way not to do it-
five pt oh is offline
Old 08-25-2007, 06:29 PM
gothand
gothand's Avatar
[sm=happybounce.gif] ^^^ Darwin Award winner?
Just this past week, a guy died here in L.A. when a car he was working on fell on him. No doubt, it was improperly supported. That said, there have been a few occasions when I was under the vehicle on properly place jackstands and thought, "we sure as heck better not have an earthquake right now."
gothand is offline
Old 08-25-2007, 07:17 PM
68FastbackGT
68FastbackGT's Avatar
Be careful if you jack the car up on the pinch welds on the rocker panes. They bend really easily.
68FastbackGT is offline
Old 08-25-2007, 09:17 PM
five pt oh
five pt oh's Avatar
also, if you're removingwheels (which is the case most of the time you jack it up), go ahead and slide those wheelsunder the car as an extra measure. It could make the difference in an an injury vs. a death if you do happen to have that earthquake while you're down there.
Quick Reply: Jacking up a Classic Mustang...
