cooling system flush
Old 09-04-2007, 02:03 AM
lucastrex
lucastrex's Avatar
Default cooling system flush
All the do it yourself flushes explain tapping into the heater hose. I don't have a heater core, so what is the best way to flush my entire system including engine. Is there a simple way using garden hose only? Recently did a chemical flush (instructions: drain, add chemical, run engine to circulate, drain) which did not result in clean fluid.
lucastrex is offline
Old 09-04-2007, 08:16 AM
andrewmp6
andrewmp6's Avatar
Default RE: cooling system flush
id just take it somewhere and be done with it
andrewmp6 is offline
Old 09-04-2007, 08:21 AM
JamesW
Moderator
JamesW's Avatar
If you don't have a heater core, then you just have a hose that loops from the waterpump up to the intake manifold. just cut that line and splice in the fitting.
JamesW is offline
Old 09-04-2007, 11:22 AM
restomod87
restomod87's Avatar
+1 James
restomod87 is offline
4cylinderplus2
10-09-2020 07:45 PM
bradleyb
11-27-2015 07:50 PM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
wraith777
09-28-2015 10:49 AM
Quick Reply: cooling system flush
