Granada Power Disc Brakes help..
I noticed that the original valve that I had in my car has a TOTAL of 4 outlets, and the one that the seller sells has a TOTAL of 5 outlets. Do I need to buy a new one or do you guys use your original ones?
-and Im installing power brakes if that makes a diffrence.
RE: Granada Power Disc Brakes help..
The 5 ports are:
1 - in from front M/C bowl
1 - out to rear brakes
1 - in from rear M/C bowl
1 - out to front right brake
1 - out to front left brake
If you're using a dual M/C you need this one.
I think you can pull these off of Mustang IIs, too. I'm not 100% sure, but I think I saw one on a 70s out in a junkyard, and it looked brand new. I would definitely suggest getting a dual MC, if you don't have that.
Alex,
You do not need to install a combo valve. You have the CHOICE ofusing acombo proportioning valve or an adjustable proportioning valve. The 4 port "valve" that you mention is not a valve, it is the brake fluid distribution block that is standard on all 65-66 drum/drum Mustangs. Your kit and 95% of kits sold included an adjustable proportioning valve. As I suggested before, you should read and follow the install guide provided with your kit at
http://www.discbrakeswap.com/The_Gra...9.3006.v01.pdf[/align][/align]Follow the guide and you should have no problems. If you have a problem understandingthe instructions, let me know.[/align]Dennis[/align]
ORIGINAL: ShAkE N BaKe!!
Im going to go to an autoparts store tomorrow and try to get a distribution block. What car/year should I ask for?
musnicki
09-23-2015 07:11 AM
maestro1024
09-21-2015 02:40 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
09-08-2015 11:50 AM
