200 cid running @ 235 deg.
[:@] I've got an 1967 200c.i.d. 3 speed man. trans w/ the under dash dealer add on A/C. it runs 230-240deg. all the time (aftermarket gauge reading) the radiator seems clean water moves through it well and have no leaks. the motor was remaned by local rebuilder that I know and trust new motor only has about 15 miles because of hot issue. the fan is a solid mount car has no fan shroud. Please help this car is my wifes boss' car I'm really want it to go home. THANKS BOB
RE: 200 cid running @ 235 deg.
240 is upper limits 220 would be nice.
What you really need right now is to get your hands on a raytec (or similar) non contact thermometer and measure the temp of the water right at 2 locations. The first spot needs to be at the top right were the hot water flows into the rad measure the temp at that joint and take a few readings to get a good idea. The second spot needs to be at the base of the rad where the second hose connects. if the water temps only differ by 10 to 15 degrees then your radiator needs to be replaced or something is up with the fan. If the water is say 240 at the top and 195 at the bottom then your rad is good and you should check to make sure there is a 180 thermostat installed and not something odd like a 200ish or something weird.
Good luck
Gun
Good luck
Gun
i've check w/ my dvom that has a temp probe and water in top of rad. was 210 and lower hose @ 185. I also checked w/ probe on head next to the sending unit and only got 213 deg. thermo is 180 deg.
Did it run hot before the rebuild? New motors are tight, and I would start off by not running the AC until break-in period is over. If the temps you posted are correct you need to get those down or they may cause engine damage/failure. Talk to your rebuilder and find out how tight this engine is, more specifically what your main and rod bearings clearancesare.Have you checked the timing if that is at one extreme or the other(retarded/advanced) will cause overheating. Has it boiled over? If it has notyou need to verify that your gauge/sender is giving you the correct readings. Good luck!
Lowell
Lowell
You should still check with your mechanic however.
Gun
