How to tell if the engine is a 390
i have a buddy that is looking at a 67 mustang with a 390 in it, is there any easy way to tell if it is a 390 because he doent think it is. Is there a definate sign like valve cover bolts, intake bolts, or distrubuter posistion or #'s on the block? any help would be great
RE: How to tell if the engine is a 390
If I'm not mistaken, if it is an FE (360/390/427/428 and others) it will have
5 Valve Cover Bolts
Distributor goes through the intake manifold
Intake goes under valve covers
2 forward facing and 2 rearward facing spark plugs on each side
5 Valve Cover Bolts
^^^I wish I could rememeber but I believe that's correct.
Another one that I can't remember if is always true: pull the valve cover off, sometimes engraved in the head will be the displacement number. at least it was on my 351...
ORIGINAL: nealro
5 Valve Cover Bolts
5 Valve Cover Bolts
All of that IS correct, but that won't help him determine which size FE could be in there, if it is an FE engine. Ford/Lincoln/Mercurybuilt many different displacement FE motors, including the 352, 410, or any of the others you listed (cuz I know I'm forgetting some).
An FE will have the intake under the valve covers, as said above.
Well the FE that it could be would be 352-360, 390-406 or 428 more than likely...if you check the stroke with a dowel by putting it on the piston and turning the crank by hand and see how far it moves up and down you can get a good idea...3.5" would be 352-360, 3 3/4" is 390-406 and 4" would be 428". This isnt a definite, but it will get you real close unless hes got an exotic engine.
AmericanMuscle4.6GT
11-10-2015 02:06 PM
TfcCDR
09-14-2015 12:08 PM
