Could it be my timing?
#21
RE: Could it be my timing?
Your classic collection is getting larger I see pammie. Where is your coil situated? asI wonder if the coil is getting too hot and your are lossing spark at these higher temperature but when cooled it is nae bother.
#22
ORIGINAL: sixtysix
I would check the points..simple fix Scott
I'm just so frustrated at this point. I'm having him adjust the timing anyway as it appears to be way off ... not sure what else I can change/replace/fix but the carb is pretty new
#25
ORIGINAL: Daze
I hate to sound like a broken record, but
"How many turns are the idle mixture screws set at, what size is the carburetor, and what size is the motor? "
#26
The carburetor for a performance based motor that size should be between 575 and 625 cfm depending on other parts. To small a carburetor will cause loss of power at high RPMs and the motor to run hot. To large a carburetor will cause the car to run rough at low RPMs especially once the motor is up to temperature. As far as the idle mixture screws, check them so we know exactly where they are set. Do this by turning the screws in ½ turn at a time and count the turns. Once the screws stop you know where the screws were set at, you can screw them back out to where they were by counting, and you will have a number for us like 2 full turns or 4 half turns. If the screws are more than 2.5 full turns out you will probably need to retune the carb. When tuning the carburetor to get a good starting point turn the idle mixture screws all the way in being very careful not to over tighten them and then back them out 1.25 turns. That is a good initial setting where you can get the motor warm so it can be properly tuned. I would still like to know what the electrode on one of your spark plugs looks like. I have found that spark plug color is a really good way to tune a carburetor. A black plug means too rich, a white plug means too lean. What you want is a nice tan toasted marshmallow color.
#27
The plugs were old and rusty and were changed and tossed.
As far as the carb, "its a brand new 4 bbl edelbrock 800cfm carb" according to the kid who knows my car.
#29
ORIGINAL: MustangPammie
#30
Ok, today I ordered a new Edelbrock 600 cfm carb with electric choke since you and others told me the carb was too big.
I guess I'll try to sell the 800 cfm since it's pretty new.
I'll have it on Monday
