408 windsor question
RE: 408 windsor question
as much as it would cost them to remachine your block for a 351 rebuild. the difference is in the rotating assembly, and you can purchase crank/rods/pistons/rings/bearings for like 1000 bucks. you MAY have to notch the bottom of the cylinders to let the rods clear with a stroker, but any guy with a die grinder or dremel tool can accomplish that
ORIGINAL: Mustang.
how much would i cost meto machine a 351 windsor to a 408?
If you use I beam rods you will need to make clearance notches on the bottom of the cylinders. When I installed the stroker crank in our 351, I requested a "tool" (free) that will show exactly where to grind the cylinders out for clearance. I used a die grinder and it took about an hour to do all 8.
Once I started assembling the bottom end, I discovered that I didn't need to clearance the block,,, duh... but it was easy....
its always better to be sure than to regret it later though.... when you do to to a 408 i would reccommend that you get all forged, and im about 100% sure everyone else will too. also go with the H beam rods they are stronger than the I beam.
you only need to go top end parts if your building a motor that requires those kinda parts to hold up. the "normal" stroker crank and I beam rods are more than enough for most streetable builds. forged pistons are a worthy investment though, so theres one area i'd rather pay a little extra for if i was building a stroker.
i know i will have to buy a crank, ect. (i plan on getting a kit from the same place as JMD, he gave a link on another post). but if i understand you guys right i don't even need to take it to a machine shop? should i get I beam rods or H?
ORIGINAL: Mustang.
You will also need to have the block deck surface cleaned up, and possibly the crank line honed. All of this is standard stuff and is inexpensive.
H or I? We went with H beams, but they are probably overkill, I beams will work fine, but then again, they are not really that expensive these days...
i don't plan on stroking some old crappy motor. i am going to buy a rebuilt 351w short block (which will be basicly brand new), and i plan on stroking that. how does that sound?
sounds like your paying for a motor twice. the same machine work that would be done to a rebuilt short block would be the same machine work you'd be doing if you started with a used, tired old 351. if you can find a later model roller block that would be best, but the earlier blocks had thicker main webs and a higher nickel content. plus, you need the cylinders bored and honed to YOUR pistons, so if you bought a short block you'd most likely be paying to get the cylinders touch honed again anyways
ORIGINAL: my77stang
What he said,,,,,
