Carb Choke
Carb Choke
How does the choke work on my carb?2bbl stock carb.. I have the unused vacume line that used to be plugged into my pass side manifold, but I havent hooked it up to the little U-tube on my headers. Will my choke work properly if I just plug the vaccume line instead of running it to the header? I just want the darned thing to run again..
RE: Carb Choke
No, it won't. It's designed to pull hot air from the exhaust to heat up the bimetal spring inside and actuate the choke. Since you don't have factory manifolds, the next best thing is toloop the metal line around a header tube. Don't worry about plugging it.
If you still have the bracket that holds a heater hose right next to the choke body, it will help that much more.
RE: Carb Choke
Here is a link to a thread about the same topic...
https://mustangforums.com/m_2915355/tm.htm
Good luck!
Good luck!
RE: Carb Choke
it's not a vacuum (or at least, mine isn't...) - it's a "heat pipe." I went to Ace hardware, cut me a bit of copper tubing, bought a compression nut, and screwed it in. Took 10 minutes.
bradleyb
11-27-2015 07:50 PM
Daddys Girls GTs
09-14-2015 08:46 PM
jaiidutch
09-14-2015 10:29 AM
