there must be another way
i am going to be running about 550 to 600+ hp in my 68, and so i need a 9" rear. but, the only problem is that i've been looking around and it looks like i am looking at around $2500+ for a 9" rear. so here comes the question......is there a cheaper way to do it? i have been hearing about 8.8", will one of those hold up? or am i just screwed over into paying lots of $$$?
RE: there must be another way
You can go to currie's or mosers website and build a bulletproof rear for less than $2500, or call them up and talk to them to see exactly what you need.
http://www.currieenterprises.com/
http://www.moserengineering.com/Pages/Axles/cclip.html
8.8 is crappy and dont bolt in your car you can get a empty housing from http://www.perogie.com/ and build it up to hold that power.im with fast66 how you gonna have that much power but cant afford 2 grand.
The torque is what is going to snap things. Are you planning to run drag slicks that will load all the torque because they hook up, or a set of street tires that will roast with 300 ft/lbs or less? Anyway if you are set on a 9, they are the toughest of the bunch. You can keep your cost down if you if you shop for a used setup. The housing can be cut to fit, the axles will need made to fit, some axles can becut and re-splinedand some can't.You may look around the junkyards before dropping agrand or two. A good Rod shop can section the housing.
Check this one out, this is where i got mine from they are pretty good.
http://cgi.ebay.com/ebaymotors/Ford-...spagenameZWDVW
8.8 won't hold up
http://www.mustangsandmore.com/ubb/F...imensions.html
