another rear end question
RE: another rear end question
cheapest place to get a 9 inch housing i trust is http://www.perogie.com/Rears.htm
Junkyard.
94+ explorer 31 spline 8.8 (3.54:1, 3.73:1, 4.10:1) stock ratio's and you get disc drakes.
only problem with them (and 500hp) is twisting the tubes, Factory is a press fit, simply truss it or weld the tubes to the punkin.
This axle is 1/2" wider than a stock 1969 ford 8"
Most 9" you will find @ the JYD will be too wide (in stock form) so you must cut down, buy custom shafts, etc.
can i build my 8" rear to handle 500+ hp, with new gears and what not? or is my only option a 9"?
91StangOwner
08-20-2015 11:34 PM
Black_GT_02
08-20-2015 01:26 PM
92 5.0stang
08-13-2015 06:46 AM
