Pitman Arm ?
Pitman Arm ?
So my Pitman Arm is hitting my Header ,someone not from this forum suggested the I grind the Pitman Arm down an 8th to 1/4 inch to get the clearance . So what do you think?
Also I have already dimpled the header some and not sure how much more I should go.
RE: Pitman Arm ?
Not a good idea. Single failure of the Pitman arm means that you have about, ummm, zero steering control. Failure of a header tube is mostly just noise telling you to hurry up and fix it. I'd cut and reweld the header tube instead.
Norm
Norm
RE: Pitman Arm ?
Sure would be a lot easier (imo) to heat up the header with a torch and then smack it with a hammer to get the clearance you need than grinding down an integral part of my steering system.
RE: Pitman Arm ?
ORIGINAL: 67mustang302
If you mess with the headers, be careful not to kink them, you want the primaries to stay as round as possible
