AFR - Wow!!
AFR - Wow!!
Well after much thought I finally decided on heads and bit the bullit. I purchased AFR 185 61cc heads and they just arrived and I just had to share with someone. I must say they are much better looking than I had thought, and the valves are huge compared to stock 302 heads anyway. They will be going on a 347 roller motor which the 61cc chambers will make the compression 10:5 to 1. The cam is a ford motorsports Z303 cam which will be backed by a T-5 for as long as it will hold together. The combination will go into my 68 coupe. Below are some pics.
[IMG]local://upfiles/47481/9575A8A0088C4882B1C59980AC8227FA.jpg[/IMG]
[IMG]local://upfiles/47481/E7B369DC48C342CEA0E8BA8309923B7A.jpg[/IMG]
[IMG]local://upfiles/47481/F681B03E9C784D4DBEE0E88AAC764D34.jpg[/IMG]
[IMG]local://upfiles/47481/8C69B638A9204E0FA523245E5BC2331B.jpg[/IMG]
[IMG]local://upfiles/47481/34D9652F0C2941B3A9FFB0C357EFD9A5.jpg[/IMG]
RE: AFR - Wow!!
someone just said the patriots were are actually a AFR molding that patriot bought from AFR. probably slightly outdated, but flow numbers are right there with the AFR's and the price is far below.
that = winner in my book
