Carpet - 1964 1/2 or 1965 ???
RE: Carpet - 1964 1/2 or 1965 ???
mustdoc and others, if you order 64 1/2 carpet from a catalog do you know if the vinyl strips are usually included? I'm starting to think I might need 64 1/2. I talked to a friend whoused to owna convertible built a few months after mine and he seems to remember having to buy 64 1/2 parts for everything.
I went ahead and did some rough measurements (I mean rough) from the floor up to the door sills (rockers I think?)I measured around the area of where the door and kick panels meet, and again where the seats rise. I came up with a little over 4 inches in both places...maybe 4 1/4 or so. It looks to me that for the 65 carpet to fit my car the floors would have to be about 2 inches higher.....which seems strange.
Can anyone with a convertible make some quick measurements?
btw...I'm not really sure what the difference is between convertible & coupe carpet, but since the catalogs stock both, I guess measurements for a coupe won't help me.
Thanks! Mike
Thanks! Mike
You learn something everyday. I figured a 65 would fit either. After all I installed my 65 carpet about 3 weeks ago and had to cut about 3 inches off each side near the door sill. (Fastback)
It is, but I wonder if it is manufacturer. I did my rear seat last night and the seat kit for the fastback were large pieces (Almost like a universal kit) because I cut of about 2 inches on each side of the long sides and about 8 inches off the end.
I still cant believe your carpet is short. I hope ot works out for you. Here is a copy below taken from the NPD catalog. It looks like they have the vinyl seperate.
1964 1/2 Carpet
This is the correct 64 1/2 style carpeting which does
not cover the sides of the rocker panel to the step plates
(Coupe only) and has the heel pad but no toe pad as
original. See vinyl yardage on page 13 to cover rockers.
Black (251), Red (256), Ivy Gold (258), Dk Blue (262),
Lt Saddle (254). Parchment (263). Add color code in
parenthesis to base number below.
Coupe .............................................CA-45-65-__ 119.95
Convertible....................................... .CA-45-76-__ 119.95
1965-67 Carpet
Correct 80/20 Nylon/Rayon blend.
Black (251), Dk Brown (252), Ford Blue (253), Lt
Saddle (254), Moss Green (255), Red (256), Maroon
(257), Ivy Gold (258), Aqua (259), Dk Green (260), 66
Emberglow (261), Dk Blue (262)
Fastback.......................................... ..CA-57-63-___ 119.95
Coupe CA-57-65-___ 119.95
Convertible....................................... .CA-57-76-___ 119.95
10-01-2015 05:13 PM
09-22-2015 12:35 PM
LivingInThePast
09-16-2015 12:20 PM
