Outside door handle question...
Any tricks i should know before i try to remove the outside door handles for paint? With the outside ones removed will the inside ones still work? or am i going to have to keep the doors closed with duck tape and rope when i drive down the road :-)
RE: Outside door handle question...
I think the insides will still work, but I used another method. Once you remove the outside handles there will be a rod still dangling there. You can manuever it to stick out of the hole in the door. Lift this rod and the door opens. It an easy removal process. Just make sure you remember how the clips go back on inside the foor.
mungodrums
09-28-2015 10:54 PM
09-25-2015 06:58 PM
mungodrums
Suspension
09-24-2015 10:12 PM
