REAR AXLE HELP PLEASE!
RE: REAR AXLE HELP PLEASE!
For a couple of grand you can get a new Currie 9" with your choice of gears, and "Traction Lock", that is 100% bolt in.... you can get disk brakes on it for afew hundred more.
This is not everyones best option, but it is something to keep in mind while looking for a used axle and the associated conversion costs.
ORIGINAL: baddog671
Currie is expensive as all hell. I was qouted well over 3k for what I want. Outta my range...
ORIGINAL: baddog671
If your main goal is tracloc, you could just pull the centersection out of the differential and replace it with another unit that already has a locker installed. 8 and 9 " share the same housing, so a 9" center would slap into yours too(so ive heard).
ORIGINAL: baddog671
a 8 inch housing with not hold a 9 inch center section. if it did why would people spend so much on 9 inch housing, everyone would be driving around with a 9 inch rear. my friend has an 8 inch on his 69, the rear is completely stock and he has a 392 stroker with over 400hp. its held up fine but i wouldnt recomend it. and i dont think youd be putting out close to 400hp with a 289. i have a 289 with the 8 inch rear and im about to drop a stroker into my car and im most likely going to rebuild my rear instead of buying a new one
11-10-2015 11:39 AM
09-10-2015 08:39 PM
Dragonus18
09-09-2015 01:21 AM
