5/16 or 3/8 rockers
RE: 5/16 or 3/8 rockers
ORIGINAL: eep4life
well being that my motor is already assembled.... and i don't have the money to get all that work done... will a normal cam... because thats all i have.. nothing to perfomie... just a stock replacement pretty much... will my motor be ok with just the normal 3/8 rockers with 5/16 nuts?
If you can, put some screw in studs in there. There's a reason they stopped using pressed in studs. Pressed in != stay in [&:]Besides, if you put some good 3/8 studs and rockers on now, you have them for later on when you put better heads on etc
Yeah, those will work. The rails are the part of the tip that goes over the side of the valve to keep the rocker arm aligned. One thing you should check, if the valves were replaced, is the clearance between the spring retainer and the rails. If they're the original valves, never mind :-)
BTW, have those heads been gone through? That first valve stem tip looks pretty hammered. Also, you need a specific nut for those studs, it has a bevel to match the one on the stud.
ORIGINAL: eep4life
well being that my motor is already assembled.... and i dont have the money to get all that work done... will a normal cam... because thats all i have.. nothing to perfomie... just a stock replacement prety much... will my motor be ok with just the normal 3/8 rockers with 5/16 nuts?
ok ill make sure ill get the right type of nut... i beleive they have been... with my experiances with the machine shop i go to... they normally tell you if everything is ok or not..... also i think the valves are older.... i think they have just been cleaned... ill need to look in to it
69MustangCoupe393cid
10-03-2015 10:33 AM
