transmission
transmission
I own a 1967 with a 6 cyl. It runs and idles fine but when I shift the auto trans into drive with my foot on the brake it shutters. I dont think its the engine, could it be the trans and if so what could be the problem? No jerking or lope at idle. it only happens when I shift to R or any D position. Ill check the vaccum hose for leaks. Would this problem have anything to do with the kick down rod or cable, maby out of ajustment?
RE: transmission
when my car was an i-6 i had that problem and it was the torque conv along with the vaccum hose not being connected. That damn hose almost cost me 1500! thank fully my transmission shop guyis a mustang fanatic and showed me what to look for and he hooked me up with a free tq conv and new vaccum hose.
RE: transmission
Typically a shuddering at idle is caused by the engine idle speed being too low. You need to verify that the engine idle is at or 550 to 600 RPM in drive or reverse. another cause of shudder is broken engine mounts.
RE: transmission
ok i went to my parents house and pull my car out and tested and duplicated your scenario (cuz i dont give a **** about this motor) and it is def low RPMS not the vacuum as i thought in my other post.
