Need help with car vibration and burning smell
Old 10-29-2007, 08:56 AM
351W
351W's Avatar
Default Need help with car vibration and burning smell
I've got a 1970 351W (all stock). Have had the car for 6 months and it runs great.
Yesterday, after 40 minutes on the road, the car started to vibrate above 40mph and had a bad burning smell.
When I pulled it over, the smell seemed to be coming from the transmission area but thta's just a guess. The temp gauge never changed.
Any idea as to what's going wrong???
thanks
351W is offline
Old 10-29-2007, 10:15 AM
DriWashSolutions
DriWashSolutions's Avatar
Default RE: Need help with car vibration and burning smell
Can you describe the smell?
How many miles on the trans?
What type of Trans - Auto or Stick?
If Auto, have you checked the trans fluid lately? Is it a nice red color, or does it look brown?
If Stick, how many miles on the Clutch/Pressure Plate?
DriWashSolutions is offline
Old 10-29-2007, 10:24 AM
boogerschnot
boogerschnot's Avatar
Well somethings not right.. Hmmm... Were there any other indications? Any smoke?
boogerschnot is offline
Old 10-29-2007, 02:52 PM
Hawkins 812
Hawkins 812's Avatar
Vibration at high speeds usually mean an alignment is due or your tires are out-of-balance....but that doesnt explain the smell. More info please.
Hawkins 812 is offline
Old 10-29-2007, 02:59 PM
jlg2002
jlg2002's Avatar
Is your emergency brake on?
jlg2002 is offline
Old 10-29-2007, 03:35 PM
Hawkins 812
ORIGINAL: jlg2002
I actually did that once and felt like a complete idiot afterwards. Smoke was coming out of the rear wheels and i was like WTF!!!....After i started it back up and started to leave, i noticed the parking brake was on. That will never happen again [&:].
Old 10-30-2007, 12:12 PM
351W
351W's Avatar
Thanks to everyone for the quick replies
It's an automatic. Checked the transmission fluid last night it it looks good. I don't know how many miles on the tranmission.
The burning smell is wierd....it's definately not a rubber belt or brake. I took it out last night and it ran fine for aabout 20 minutes than the vibration and buring smell came back when I had it on the highway doing 50mph+
Something's definately wrong but I don't know who to take it to (tranmission shop...front end specialist...etc.).
Once again, thanks to everyone for their input.
351W is offline
Old 10-30-2007, 06:57 PM
dcohen
dcohen's Avatar
start with a front end alignment, and get your tires balanced
does it vibrate when your moving slow?
dcohen is offline
Old 10-30-2007, 07:04 PM
Matt.69Stang
Matt.69Stang's Avatar
It doesn't make sense that when he's going fast, he begins to feel the vibration and a burning smell. Could his wheel bearings be getting too hot and scoring the metal and causing the vibration?
Matt.69Stang is offline
Old 10-30-2007, 07:09 PM
DriWashSolutions
Can you feel the vibration is the steering wheel? If so, it could be also be two independent issues:
If Yes: wheel balance / front end play / loose lugnut(s) = vibration
If No: wheel balance / drive shaft /loose lugnut(s) = vibration
Smell - engine burning oilat high RPM / Engine oil leak / trans oil leak
Quick Reply: Need help with car vibration and burning smell
