How hard is it to install a Hood Scoop
RE: How hard is it to install a Hood Scoop
ORIGINAL: dodgestang
You know....I actually don't recall ever seeing a body color 69 style scoop....I guess I don't get out much
I still like the blacked out better though
Location: Detroit; where the weak are killed and eaten.
SHAKERRRRRRR
Mine was originally a 302 2bbl car, and I put on a 4bbl intake and carb early on and decided wanted the shaker; took a hgh-rise intake, 1 inch carb spacer, and finding a shaker base assembly set up for a 351w (not altogether too common) to make the combo work riight but it was an exceptional look for even a mild 302.
Now it looks as bad as it performs on my 351w.
(Is going to be more cleaned up by spring, but to give the idea... )
We got the bond on style hood scoop. Used a couple of aircraft counter-sunk rivets to hold it in place at the start, fiberglassed it on and then smoothed it all out with (I know I'm going to catch hell for this)...........bondo. Looks good and its functional. We will be painting over it and adding rally stripes. The next task will be adding side scoops next weekend.
i have two questions... one alot of you mentioned the turn signal wires.. im confused about this... i have a 69 and i dont have any wires going in to my hood and i dont see why adding a scoop would get in the way of the turn signal wires.... and two i do like the look of a shaker kit but since the scoop is exposed can it be ran in the rain?
ORIGINAL: eep4life
As for the shaker not letting your car being ran in the rain.... I'm sure if your driving very little water will be actually going in there. If ford put it on in the 60's for people to drive around, i'm sure it can be driven today.
ORIGINAL: eep4life
Sure my car can be ran in the rain (though that doesnt mean that it DOES) anything with functional ram air can be, as long as you aren't dumping water down down it. This goes for all functional 69-70 scoops, shaker assemblies, and 71-73 NACA hoods. It has a seal (seen in my 2nd pc) that meets around the hole in the hood, so anything that gets around the shaker into the engine compartment drips through a hose down toward the ground, and none really every gets into the shaker, and if it did, it makes its way nto the base assembly which also has a drain built in. (Though I am mssing the snorkel in the pics, it is on there now)
But to me nothing beats the look of a shaker. Just a classic muscle look on any car.
f I didnt have th shaker though, Id've definitely put on the scoop. It's a solid look, with a blacked out hood, OR same color as car.
In fact, I think I might go buy a Boss 429 Hood scoop for my 01 F-150 lol.
You can get Cobra-Jet style scoops without the provisions for the turn signal indicators. Also, to make it functional you don't necessarily have to cut one big giant hole in the hood. You could just cut a few smaller holes with a hole saw, like maybe two or three 4" holes.
BTW, anyone know where I can get an repro cobra jet air cleaner for a 70' with 351W. I'm looking for the air cleaner, hood seal and all.
Thanks,
John B.
Thanks,
John B.
