69-70 Window Guide Bushing / Grommet
RE: 69-70 Window Guide Bushing / Grommet
Have you thought about doing a 70' bolt in conversion? The '69 glue-in windows will leak inevitably sometime down the road....just my advice. I did mine w/o any modifications or trouble.
How much would this cost do to? how much of the 69 stuff will have to be replaced with the '70?
I have all my windows out and one of them has to be reglued cuz the stupid PO doesn't know how to align windows and the tracks are way off. How much is involved with this '70 mod?
ORIGINAL: 4reboy
I made my own for the 69 mach. I took the old ones out and glued some dense foam to the old ones and greased them down. Oh, these are a pain in the butt to remove by the way (brackets not the guides). If your window rattles bad, new ones will not help, they need to be thicker, hence the foam I put on mine. It also helps to make sure the guide rods are firmly attached. I had to re-weld one of mine.
09-25-2015 06:30 PM
