cost of AOD
cost of AOD
Well, I'm waiting to hear back from this place that makes all kinds of trans adapters and if it works out might get an AOD for my I6 if they can make an adapter for it. My question is though how much will a good built AOD cost? I'm not racing it just planning on cruising in it, but am thinking of getting the aluminum head they've developed at fordsix.com which would bump up power. Where is a good place to get one strong enough for my application and how much should it cost? Thanks! If this doesn't work I guess it's gear vendors...
RE: cost of AOD
ummm, sorry to tell you, but well, i dont think you can find an AOD you can break with a I6, lol
i mean, maybe turbo it with the alum. head, but its kinda a six popper from the 60's. you should prob be able to find an AOD anywhere really for the power, as far as i know, they were all ready for an 8 cylinder
RE: cost of AOD
ORIGINAL: middiepride
RE: cost of AOD
I have smashed 2 stock aods in stock fox bodys and i have seen this http://www.mustangmonthly.com/featur...age/index.html 240k on the aod with no rebuild it all depends on how you take care of things and how hard you drive it.
RE: cost of AOD
That is good to know. Where should I get one from then, there are some on ebay I've seen for just like $500
http://cgi.ebay.com/ebaymotors/86-92...spagenameZWDVW
or http://cgi.ebay.com/ebaymotors/AOD-M...spagenameZWDVW
I would rather have a rebuilt than remanufactured one. Any good places you would recommend?
RE: cost of AOD
Word on the street is that the 4R70W is the way to go instead of the AOD. It will handle all the power your 6 cylinder can make plus you can pick one up fairly cheap. The downside is that you need a controller for it, but the controller also allows you to adjust the transmission with a computer.
Heres a thread about it:
https://mustangforums.com/m_4019450/...tm.htm#4019450
RE: cost of AOD
I've got the AOD that came from the donor 89 Mustang. I plan on using it until it goes out then upgrading to the 4R70W.
To be honest, I didn't know anything about the 4R70W when I started otherwise I might have gone that route instead.
jwog666
12-27-2021 08:09 PM
