size 40 tires
size 40 tires
hey ive got a friend that has a set of 17x8 torque thrusts that came off his 69. the back size tires are 40s and the fronts are 45s. anyone have a picture or about how big they would look?
RE: size 40 tires
ORIGINAL: 4reboy
why would the bigger tires be in the front?
A 255/40 run in the rear and a 235/45 or 225/45 run in the front net out to almost identically sized tires (diameter) with visual side profiles that match.
I used to run a 255/40 rear and a 235/45 in the front. With the brand of tires I was running I did net out to a front tire that was .1 inch taller but as soon as the weight of the car was on who could tell
RE: size 40 tires
ORIGINAL: dodgestang
Just because the sidewall profile number is numerically higher between two tires doesn't mean the one with the higher profile is nessecarily taller.
