Battery Relocation for 65 Fastback
RE: Battery Relocation for 65 Fastback
Yep, the neg you can ground to the trunk floor, scrape paint to make a good connection. Run pos thru the cabin to the eng compartment. Make sure you have a good ground from engine to firewall. I've also heard audio cable works well, some say run 4 ga. but I think 0/1 is best.
One thing to consider, is if you go to a track that enforces the rules more strictly, they'll require you to have a safety shutoff switch clearly visible and marked on the rear of the car if you have a relocated battery
Check out JamesW's site....
http://www.midnightdsigns.com/Mustang/Battery.htm
He did a write up of relocating the battery in his fastback. Same difference, and it really cleans up the engine compartment!
Sample for you.
[IMG]local://upfiles/55532/5211950559A543139101291171D8EDA8.jpg[/IMG]
[IMG]local://upfiles/55532/443242F99B584028BD6BF78668A79269.jpg[/IMG]
[IMG]local://upfiles/55532/DB2E6E58F6F046DABB716539D91541F3.jpg[/IMG]
09-24-2015 09:18 PM
1965, 1966, 65, 67, area, battery, fastback, ford, instructions, kit, mustang, relocate, relocating, relocation, trunk
