Neutral safety switch
RE: Neutral safety switch
Youcan access it by lifting the car or driving it onto ramps. It's on the driver's side of the C-4. To remove you all you have to do is remove the nut holding the selector lever on, undo the two bolts holding the safety switch on, then slide the switch off the manual lever. The wiring has a disconnect both at the switch and at the firewall.
Pretty easy to swap butI had to tinker a bit to get it lined up and working properly. You mighthave some slop in your shifter linkagesthat will have to be addressed as well.
F14chuck
'69 302 C4
F14chuck
'69 302 C4
