setting timing
Old 11-12-2007, 07:15 PM
jman67
jman67's Avatar
Default setting timing
Hi, I just put in a new ford racing342 crate engine. i am trying to set the timing on it. the manual says recomended timing is 36 to 38 degrees at 4000rpm. It does not say anything about the timing at idle.could anyone tell me what the timing should be at idle.
jman67 is offline
Old 11-12-2007, 07:59 PM
Starfury
Starfury's Avatar
Default RE: setting timing
Probably 10-14* with the vacuum advance disconnected and plugged. Set it at 14 and take it up a steep hill in high gear under light acceleration and listen for pinging. If it pings, back it off a couple degrees and try again.
Starfury is offline
Old 11-13-2007, 08:36 AM
kalli
kalli's Avatar
if you have a proper timing strobe where you can change the advance in degrees, set it to 36 advanced.
Rev the engine to 4000rpm and turn the distri so that it flashes the mark at 0 degrees.
if you don't, then use what Starfury says.
If the engine is brand new, Ford Racing should be able to help you with such details as well.
Kalli
kalli is offline
Old 11-13-2007, 10:40 AM
palerider
palerider's Avatar
Jman just curious where did you get ther motor and have not seen much published on HP or Torque - any estimated numbers you can share. Planning on putting new crate in my 70 Fastback. Just looking at my options. thanks
palerider is offline
Old 11-13-2007, 12:39 PM
67mustang302
67mustang302's Avatar
What distributor do you have? Set the total timing at around 36-38 and see how it runs. Set the advance curve to get full advance by about 2,500-3,000rpm. Then drive it and see how it does, it may want more, it may want less. You basically want to get the best throttle response and fastest acceleration, and best part throttle power, but all without pinging
67mustang302 is offline
Old 11-13-2007, 04:16 PM
jman67
jman67's Avatar
ORIGINAL: palerider
I got the engine through cj pony parts. Its made by ford racing. It ison the ford racing website but it is hard to find on the site. Idon't know exactly the horsepower it puts out but ford says thier 302 puts out 345hp withEFI and long tube headers. I have a 600cfm carb and long tube headers so I think it should be in the area of 300. I just got finished the swap and I havent opened it up all the way yet.
jman67 is offline
Old 11-13-2007, 04:21 PM
jman67
jman67's Avatar
ORIGINAL: 67mustang302
I have an MSD distributor I think it is the billet or pro billet. Also I have the electronic control box. there is no vacum advance for this distributor.
jman67 is offline
Old 11-13-2007, 09:09 PM
jcomp
jcomp's Avatar
ORIGINAL: jman67
ORIGINAL: palerider
I got the engine through cj pony parts. Its made by ford racing. It is on the ford racing website but it is hard to find on the site. I don't know exactly the horsepower it puts out but ford says thier 302 puts out 345hp with EFI and long tube headers. I have a 600cfm carb and long tube headers so I think it should be in the area of 300. I just got finished the swap and I havent opened it up all the way yet.
A properly tuned carburetor should make the same power as properly tuned EFI.
jcomp is offline
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
mdj89
09-06-2015 11:08 PM
09-02-2015 08:40 PM
cbird1177711
09-02-2015 04:12 PM
Quick Reply: setting timing
