cam bearing
cam bearing
i am about to put my engine back together, new (crank) bearings, piston rings .
while cleaning the engine i noticed some wear on a cam bearing:
i will use the "old" camshaft , i had it inspected and the mechanic told me the cam is still fine , but would i need new cam bearing or is this not that important ?
thank you
arthur
thank you
arthur
RE: cam bearing
Doesn't look like that big a deal, especially since it's at the top side of the bearing which sees the least amount of load. As long as the journals are around on the came and the cam is straight there shouldn't be an issue. It ran before with the same cam and bearings, right?
RE: cam bearing
ok. thanks.. and i was thinking the same.. it ran before with the same cam and bearing.. they are a team already ....anyway i will keep it like it is now.. and can i continue putting the engine back together.
arthur
arthur
KingRando
10-02-2015 08:06 AM
junior04
09-28-2015 10:53 AM
