Overcarburetion FTL!
RE: Overcarburetion FTL!
Roller cam and most overhead cam performance engines can manage to pull 90% VE or more if they're well built(good heads, induction etc), but yeah, less than 100% for sure which means a smaller carb than it would need with a higher VE. That's why it's still shocking how many people are putting 750cfm or larger carbs onstreet 289/302s. If a Cup car can pull 105-110% VE(possibly more)with a carb that's 20% "too small", then it's hard to see why someone could think that smaller(or rather properly sized) carbs are "too small" to make power on street engines.
Another apect is airflow velocity. The cars operate at higher speeds = more ram air/inlet pressure which is conducive to better high RPM performance.
At idle/ low speeds/launch - a one bbl is 'best'. As you increase RPMs and increase flow requirements a 2bbl and then a 4 bbl (and then a six pack...) is 'best'.
So i ask - what is your RPM range 'goal'? High speed oval or stoplight launch? It could change the recommended CFM carb (but really only slightly - i.e. half a size smaller or half a size larger... since we don't have 'custom' sizes or true variable venturi carbs).
My advice? When in doubt pick the smaller carb for the application. Just don't go down more than 100cfm than common/recommended application would dictate.
Here is another thought to the whole restrictor mess. When they were allowed to build special engines for restrictor plate races they used larger ports on the restricted engines than on the unrestricted.
I think the most amazing thing is that even with restrictor plates and small carbs, they can still find all that power somewhere in the combination. And yeah, carb sizing is gonna depend on the application, which gets right back to why people stick large carbs on street cars, when for 90% of the driving a street car sees, the smaller carb is better. Certainly most street cars are a tradeoff of some top end power for some bottom end power, mileage, drivability, throttle responseetc, but it would seem the Nextel guys have proven that lots of top end can still be had from a restricive induction system, so on a street car there's no need to go huge to get power. I wonder what their manifold vacuum is at peak power. Certainly there is a difference with a restrictor plate engine too in the heads, cam etc, but again, it would seem they've proven that it can be worked around to still find power
And yeah, I guess I shouldn't be giving away all the secrets....want the Bushes Baked Beans recipe?
ORIGINAL: my77stang
are those rhodes lifters noisy?
If you don't mind thevalve clatter, they're well worth the price.
2000AZ5.0GT
12-15-2008 03:31 PM
