Couple of suspension questions
When dealing with your suspension, is it really worth the money to put all new components in if you're going back basically stock? Most of my bushings and what have you are showing their age and certainly need to be replaced, but, visually, the metal components look to be in good shape. Is there any advantage to buying the kits like you find at Laurel Mountain and replacing everything?
I'm definitely planning to replace my rear springs because I want the rear end to sit up a little higher and I think I have some sag there. Right now I'm at roughly 25" in the front and back from top of fender to ground. That's a little lower than stock right? I'm trying to decide whether I want to raise the rear up a little higher than stock or not. I definitely want both ends to be at least where they are supposed to be.
Thanks for any advice.
Morg68stang
P.S. I would include a pic if I could get my phone to send them on e-mail. My avatar is a pic of the car, but it's sitting at an angle so you probably cant really tell what you're looking at.
Morg68stang
RE: Couple of suspension questions
Im cheap i rather rebuild everything i could id replace things if there cracked,broke rust holes etc etc. I would replace the springs and shocks front and rear.A couple things id change are roller spring perchs baer tracker tie rod ends monte carlo bar and export brace.
I agree with Andrew, replace the springs and shocks both front and rear. I would replace ALL the bushings. The roller spring pearches are great, but will make the front of your car sit a bit higher, so you will have to cut the springs some. I would also consider replacing your tie rod ends as well.
You dont need the roller if your going to stock.I will prob change to them but my susp is setup pretty nice for handling.I replaced absolutely everything to do with the suspension, then you know youve eliminated weak points.Metal stresses and becomes weak even if you can see it.
I got the Laurel Mountain kit and I'm very happy with it. It is very complete and uses the right kind of bushings. I think if you were to try to replace all worn bushings and rod ends, etc., you'd spend almost as much money and a whole lot more time.
I think the roller spring perches are overkill for a street car, but the monte carlo bar and export brace are very worth while. I would also do sub-frame connectors.
+1 for the money you spend on getting the bushings, springs, rod-ends, etc. and the time it will take to change all these out, your best bet is the whole kit and be done with it. You never know when you start pulling those components off when something is shot until its too late. Also, don't forget your ball joints. You can replace the upper but have to buy the lower as a kit already pressed into the control arm. I got a suspension kit from Laurel Mountain as well. Nice kit.
ORIGINAL: TexasAxMan
I would rebuild your UCAs rather than buying new because even if you bought new you are better of rebuilding them so that grease grooves can be cut in to the shafts, the cap nuts can be tack welded in to place, the cap nuts don't need to be tightened so much that it puts the shaft in a bind, and so that you can offset the shafts for extra caster.
I did mine a couple months ago. I replaced everything front and rear. The car is 40+ years old, and I have only had it about 5 months. I didnt like not knowing the history, so now I have a fresh start on the bottom of the car. Now I just have to work my way up to the body and engine
